| Serial No. | Type | Machine Description | Date |
| 250 | Chucking Machines | #76H Chucking Machine | Dec 1935 |
| 475 | Chucking Machines | #76H Chucking Machine | Dec 1947 |
| 45-4109-1 | Transfer Presses | #3 Multiple Transfer Press | Dec 1935 |
| 46-4109-19 | Transfer Presses | #3 Multiple Transfer Press | Dec 1947 |
| 44-4063-1 | Transfer Presses | #4 Multiple Transfer Press | Dec 1947 |
| 40-3566-1 | Transfer Presses | #5 Multiple Transfer Press | Dec 1935 |
| 42-3566-3 | Transfer Presses | #5 Multiple Transfer Press | Dec 1947 |
| 37-442-11 | Open Back Bench Presses | #1 Open Back Bench Press | Dec 1935 |
| 45-442-78 | Open Back Bench Presses | #1 Open Back Bench Press | Dec 1947 |
| 38-883-1 | Open Back Bench Presses | #2 Open Back Bench Press | Dec 1935 |
| 46-883-78 | Open Back Bench Presses | #2 Open Back Bench Press | Dec 1947 |
| 41-3636-1 | Four Slide Wire Forming Machine | #00 Four Slide Wire Forming Machine | Dec 1935 |
| 46-3636-53 | Four Slide Wire Forming Machine | #00 Four Slide Wire Forming Machine | Dec 1947 |
| 39-1628-1 | Four Slide Wire Forming Machine | #1 Four Slide Wire Forming Machine | Dec 1935 |
| 46-1628-64 | Four Slide Wire Forming Machine | #1 Four Slide Wire Forming Machine | Dec 1947 |
| 38-1606-1 | Four Slide Wire Forming Machine | #2 Four Slide Wire Forming Machine | Dec 1935 |
| 46-1606-72 | Four Slide Wire Forming Machine | #2 Four Slide Wire Forming Machine | Dec 1947 |
| 38-3200-1 | Four Slide Wire Forming Machine | #3-24 Four Slide Wire Forming Machine | Dec 1935 |
| 46-3200-26 | Four Slide Wire Forming Machine | #3-24 Four Slide Wire Forming Machine | Dec 1947 |
| 38-1440-1 | Four Slide Wire Forming Machine | #4-5 Four Slide Wire Forming Machine | Dec 1935 |
| 47-1440-31 | Four Slide Wire Forming Machine | #4-5 Four Slide Wire Forming Machine | Dec 1947 |
| 40-271-1 | Four Slide Wire Forming Machine | #8 Four Slide Wire Forming Machine | Dec 1935 |
| 47-271-1 | Four Slide Wire Forming Machine | #8 Four Slide Wire Forming Machine | Dec 1947 |
| 43-3820-1 | Vertical Continuous Lathe | #54VC Vertical Continuous Lathe | Dec 1935 |
| 45-3820-13 | Vertical Continuous Lathe | #54VC Vertical Continuous Lathe | Dec 1947 |
