Decals - Rockwell Mfg. Co.
RSS
Modified on 2013/08/09 22:24 by Larry Buskirk Categorized as Decals
The entry looks like this:
Rockwell Mfg. Co.
Rockwell Small Decal 1
Rockwell Small Decal 1"
Rockwell Switch Plate Decal
Rockwell LVC
Rockwell/Delta 37-220 Patent Decal(ca 1965)-Submitted by Peter Hudy
(Original was white background inside black boarder, clear outside. Image updated 04-24-2009)(Right click and select "Save Target As" or "Save Link As" to download High-res version)
1966 WM BS Patent Decal-Submitted by Larry Buskirk
