Brown & Sharpe Mfg. Co.
Modified on 2015/11/13 21:05 by Joel Havens — Categorized as: Manufacturer Information
        Last Serial Number for each year.
Machine Tool Line1919192719351947
#0 Omniversal Milling Machine   12197
#1½ Universal Milling Machine, Standard Type17951969
#1A Universal Milling Machine 294930333100
#2 Universal Milling Machine, Power Feed 294930333100
#2 Universal Milling Machine, Light Type  62229200
#2A Universal Milling Machine, Power Type445354465480
#2A Universal Milling Machine, Standard Type  61318800
#2A Universal Milling Machine, Special  5971
#3 Universal Milling Machine16251936
#3A Universal Milling Machine16262086
#3A Universal Milling Machine, Standard Type  21912744
#3A Universal Milling Machine, High Speed  2207
#3A Universal Milling Machine, Heavy1703
#4A Universal Milling Machine883999
#4A Universal Milling Machine, Standard Type  1019
#00 Plain Milling Machine536609
#0 Plain Milling Machine237030213243
#OY Plain Milling Machine246929093363
#OB Plain Milling Machine  3326
#OYB Plain Milling Machine2557
#1YB Plain Milling Machine  2047
#1 Plain Milling Machine1674
#1B Plain Milling Machine 19722102
#1Y Plain Milling Machine17491976
#2Y Plain Milling Machine 37854181
#2YB Plain Milling Machine  4141
#2 Plain Milling Machine, Power Feed32253702
#2 Plain Milling Machine, Light Type  42625858
#2 Plain Milling Machine3225
#2 Plain Milling Machine, Standard Type  42285827
#2 Plain Milling Machine, Special  4160
#2 Plain Milling Machine, High Speed  2170
#3 Plain Milling Machine13481538
#3 Plain Milling Machine, Hand Feed1383
#3B Plain Milling Machine15931769
#3B Plain Milling Machine, Standard Type  17722205
#3B Plain Milling Machine, High Speed  1778
#3BH Universal Milling Machine, Heavy 1630
#4B Plain Milling Machine, Hand Feed813927
#4B Plain Milling Machine, Standard Type  957
#5B Universal Milling Machine, Heavy424464
#12 Plain Milling Machine2336248927095119
#13B Plain Milling Machine753875921
#21 Plain Milling Machine22133216
#22 Plain Milling Machine  40
#33 Plain Milling Machine  30
#45 Plain Milling Machine10
#1 Vertical Spindle Milling Machine86011071126
#2 Vertical Spindle Milling Machine, Standard Type77391610382136
#2 Vertical Spindle Machine, High Speed  1028
#2 Vertical Spindle Machine, Light Type   2283
#3 Vertical Spindle Milling Machine575688
#3 Vertical Spindle Milling Machine, Standard Type  750
#5 Vertical Spindle Milling Machine316
#1 Universal Grinding Machine2775325736275637
#2 Universal Grinding Machine2461289532925261
#3 Universal Grinding Machine2039228524803225
#4 Universal Grinding Machine1297136714321745
#30 Auto Thread Grinding Machine2
#5 Plain Grinding Machine   1737
#10 Plain Grinding Machine881110711841494
#11 Plain Grinding Machine177620762241
#12 Plain Grinding Machine410457461697
#14 Plain Grinding Machine411540
#16 Plain Grinding Machine294324
#20 Plain Grinding Machine  2147
#22 Plain Grinding Machine   152
#23 Plain Grinding Machine   38
#30 Plain Grinding Machine  58
#30A Plain Grinding Machine  58
#30B Plain Grinding Machine  58
#32 Plain Grinding Machine  33
#32A Plain Grinding Machine  35
#33 Plain Grinding Machine  20
#35 Plain Grinding Machine  16
#2 Disc Grinding Machine84
#1 Surface Grinding Machine44
#2 Surface Grinding Machine, Power Feed569879481006718829
#2B Surface Grinding Machine, Hydraulic Feed  1004918841
#5 Surface Grinding Machine  112187
#0 Tool Grinding Machine18472307
#1 Tool Grinding Machine12541451
#2 Cutter Grinding Machine11191246
#3 Universal Cutter & Reamer Grinding Machine197321632275
#5 Cutter & Tool Grinding Machine   7
#10 Cutter & Tool Grinding Machine   1394
#13 Universal Tool & Grinding Machine1499208927366318
#3 Auto Gear Cutting Machine162317741829
#3 Auto Gear Cutting Machine, Heavy1636
#4 Auto Gear Cutting Machine752803827
#5 Auto Gear Cutting Machine232
#6 Auto Gear Cutting Machine260279
#13 Auto Gear Cutting Machine903
#13H Auto Gear Cutting Machine, Heavy75310181052
#34 Spur Gear Hobbing Machine 6287
#34 Spur Gear Hobbing Machine 63101
#0 Wire Feed Screw Machine1021136015402054
#1 Wire Feed Screw Machine1186154217322940
#2 Wire Feed Screw Machine1588191922083451
#2F Wire Feed Screw Machine154219492109
#4 Wire Feed Screw Machine893949
#6 Wire Feed Screw Machine6893760
#10 Wire Feed Screw Machine 68154
Automatic Screw Machines19351936193719381941194219431945
#00 Automatic Screw Machine1257612869 13866139501523317218 18529
#0 Automatic Screw Machine 7834 8152 9997117501245913413
#2 Automatic Screw Machine      108011136312693
