Page Revision: 2008/07/14 22:54
Back to main Babbitt PageBabbitt Identification
Magnolia Anti-Friction Metal
 Magnolia Anti-Friction Metal |
Adamant Super-Genuine Babbitt
 Adamant Super-Genuine Babbitt |
Stonewall Coppered Babbitt
Stonewall Babbitt
Made by the United American Metals Corporation, Stonewall Babbitt has been around for many years and is still being sold today through industrial supply houses such as
McMaster-Carr. This is a Lead Based Babbitt is among the least expensive babbitt that you can buy. Composition is 80.25 percent Lead (Pb), 14.75 percent Antimony (Sb) and 5 percent Tin (Sn). While this material would work fine for light duty and low speed applications, for just a little more money, you can get a much better quality material. Probably best to shy away from for most machinery applications.
