Page Revision: 2008/07/14 22:57
Back to main Babbitt PageBabbitt Identification
Magnolia Anti-Friction Metal
 Magnolia Anti-Friction Metal |
Adamant Super-Genuine Babbitt
 Adamant Super-Genuine Babbitt |
Stonewall Coppered Babbitt
 Stonewall Babbitt |
Made by the United American Metals Corporation, Stonewall Babbitt has been around for many years and is still being sold today through industrial supply houses such as
McMaster-Carr. This is a Lead Based Babbitt is among the least expensive babbitt that you can buy. Composition is 80.25 percent Lead (Pb), 14.75 percent Antimony (Sb) and 5 percent Tin (Sn). While this material would work fine for light duty and low speed applications, for just a little more money, you can get a much better quality material. Probably best to shy away from for most machinery applications.
Also made by the United American Metals Corporation, this is brand is advertised the highest grade of Babbitt metal made by that company. According to their literature, there is no speed too high; no lead too heavy; no shock too great for Government Genuine Babbitt. This Babbitt is alloyed by the Stanley Process. It is especially adapted for band-saws, connecting rods, clay products machinery, converters, crank-pins, crushers, crushing-rolls, compressors, cutters, centrifugal pumps, dynamos, gas engines, marine engines, mill gearings, saw-mill, arbors, trimmers, steam cylinders, steam pumps, swing saws, turbines and tube mills. Ideal for automobiles, buses, diesel engines, and airplanes.
