Page Revision: 2008/07/14 23:08
Back to main Babbitt Page
Babbitt Identification
Magnolia Anti-Friction Metal
Adamant Super-Genuine Babbitt
Stonewall Babbitt
Stonewall Babbitt
Stonewall Babbitt
Stonewall Babbitt
Stonewall Babbitt
Made by the United American Metals Corporation, Stonewall Babbitt has been around for many years and is still being sold today through industrial supply houses such as McMaster-Carr. This is a Lead Based Babbitt is among the least expensive babbitt that you can buy. Composition is 80.25 percent Lead (Pb), 14.75 percent Antimony (Sb) and 5 percent Tin (Sn). While this material would work fine for light duty and low speed applications, for just a little more money, you can get a much better quality material. Probably best to shy away from for most machinery applications.
Government Genuine
Government Genuine
Also made by the United American Metals Corporation, this is brand is advertised the highest grade of Babbitt metal made by that company. The composition is 89% tin, 7 1/2% antimony, and 3 1/2% Copper. According to their literature, there is no speed too high; no lead too heavy; no shock too great for Government Genuine Babbitt. This Babbitt is alloyed by the Stanley Process. It is especially adapted for band-saws, connecting rods, clay products machinery, converters, crank-pins, crushers, crushing-rolls, compressors, cutters, centrifugal pumps, dynamos, gas engines, marine engines, mill gearings, saw-mill, arbors, trimmers, steam cylinders, steam pumps, swing saws, turbines and tube mills. Ideal for automobiles, buses, diesel engines, and airplanes.
Manganese Babbitt Metal
Yet another brand of babbitt metal made by United American Metals Corporation. This lead based babbitt is 5% Tin, 14 3/4% Antimony, and with the remaining ballance being Lead.
According to their literature: There is no bearing that covers so wide a scope of service as Manganese Babbitt. Easy to cast. Makes a solid bearing and is practically self-lubricating.
Especially adapted for auxiliary pumps bagasse carriers, beaters, calendars, car axles, chemical agitators, clay machinery, conveyors, cotton-mill machinery, cottonseed oil machinery crystallizer drives, driving shafts, elevators, Fourdriniers, hoisting machinery, hydraulic presses, knitting machinery, light capacity pumps, light capacity pumps, light saw-mills, mixing mills, pulverizes, sausage grinders, saw mandrills, saw tables, shapers, woodworking machinery.
