Page Revision: 2008/07/14 23:21
Back to main Babbitt PageBabbitt Identification
Magnolia Metal Corporation
The
Magnolia Metal Corporation sold several grades of Babbitt. Still in business today, you can still purchase large quantities of these Babbitt metals directly from Magnolia.
Magnolia Anti-Friction Metal
 Magnolia Anti-Friction Metal |
Sold by the
Magnolia Metal Corporation, Magnolia Anti-Friction Metal is still available for purchase today. Introduced in 1886, Magnolia Metal (as it was commonly referred to) was advertised as the best bearing material known to man and far superior than any other Babbitt. While there is no doubt that Magnolia Metal had it's applications and did generally perform well, it also has some limitations. Magnolia Anti-Friction Metal is a primarily lead based material, consisting of approximately 80% Lead (Pb), 15% Antimony (Sb) and 5% Tin (Sn).
Adamant Super-Genuine Babbitt
 Adamant Super-Genuine Babbitt |
Sold by the
Magnolia Metal Corporation, Adamant Super-Genuine Babbitt is still available for purchase today. Exact composition is not know but this is a tin based babbitt and suspected to be a similar formula as original Babbitt.
United American Metals Corporation
Stonewall Babbitt
 Stonewall Babbitt |
 Stonewall Babbitt |
Made by the
United American Metals Corporation, Stonewall Babbitt has been around for many years and is still being sold today through industrial supply houses such as
McMaster-Carr. This is a Lead Based Babbitt is among the least expensive babbitt that you can buy. Composition is 80.25 percent Lead (Pb), 14.75 percent Antimony (Sb) and 5 percent Tin (Sn). While this material would work fine for light duty and low speed applications, for just a little more money, you can get a much better quality material. Probably best to shy away from for most machinery applications.
 Government Genuine |
Also made by the
United American Metals Corporation, this tin based Babbitt is advertised as the highest grade of Babbitt metal made by that company. The composition is 89% tin, 7 1/2% antimony, and 3 1/2% Copper. According to their literature, there is no speed too high; no lead too heavy; no shock too great for Government Genuine Babbitt. This Babbitt is alloyed by the Stanley Process. It is especially adapted for band-saws, connecting rods, clay products machinery, converters, crank-pins, crushers, crushing-rolls, compressors, cutters, centrifugal pumps, dynamos, gas engines, marine engines, mill gearings, saw-mill, arbors, trimmers, steam cylinders, steam pumps, swing saws, turbines and tube mills. Ideal for automobiles, buses, diesel engines, and airplanes.
Manganese Babbitt Metal
 Manganese Babbitt Metal |
Yet another brand of babbitt metal made by
United American Metals Corporation. This lead based babbitt is 5% Tin, 14 3/4% Antimony, and with the remaining ballance being Lead.
According to their literature: There is no bearing that covers so wide a scope of service as Manganese Babbitt. Easy to cast. Makes a solid bearing and is practically self-lubricating.
Especially adapted for auxiliary pumps bagasse carriers, beaters, calendars, car axles, chemical agitators, clay machinery, conveyors, cotton-mill machinery, cottonseed oil machinery crystallizer drives, driving shafts, elevators, Fourdriniers, hoisting machinery, hydraulic presses, knitting machinery, light capacity pumps, light capacity pumps, light saw-mills, mixing mills, pulverizes, sausage grinders, saw mandrills, saw tables, shapers, woodworking machinery.
National Lead Company
Info goes here
