Page Revision: 2008/03/29 16:17
Magnolia Anti-Friction Metal
 Magnolia Antifriction Metal |
Adamant Super-Genuine Babbitt
 Adamant Super-Genuine Babbitt |
Stonewall Babbitt
 Stonewall Babbitt |
Made by the United American Metals Corporation, Stonewall Babbitt has been around for many years and is still being sold today through industrial supply houses such as
McMaster-Carr. This is a Lead Based Babbitt and among the cheapest babbitt that you can buy. Composition is 80.25 percent Lead (Pb), 14.75 percent Antimony (Sb) and 5 percent Tin (Sn). While this material would work fine for light duty and low speed applications, for just a little more money, you can get a much better quality material. Probably best to shy away from for most machinery applications.
