Page Revision: 2008/07/26 22:33
Types of Babbitt
Babbitt Classification
LIMITS |
Surface Speeds
(# of Ft/min) |
LOAD
(Lbs/sq.in.) |
MIN. |
MAX. |
MIN. |
MAX. |
Tin-Based Babbitts |
1,000 |
2,400 |
0 |
2,000 |
Lead Based Babbitts |
100 |
1,000 |
0 |
500 |
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Lead Based Babbitt is the least expensive babbitt that you can buy. It is also the softest type of Babbitt. While this material would work fine for light duty and low speed applications such as a band saw arbor, for just a little more money, you can get a much better quality tin based material.
Within the category of the lead based babbitts, there are several types - such as a lead based coppered babbitt. While still classified as a lead based babbitt, this mid-grade Babbitt product, it is generally considered a better material than plain lead based babbitt because of the alloy mix.
Tin Based Babbitt
Among the many standards ASTM has, different grades of Babbitt are included. As such, many manufacturers of Babbitt will often provide a ASTM Grade for different brands of Babbitt, allows consumers to compare one product to another knowing that its composition is similar.
ASTM Babbitt Analysis Chart
ASTM B-23
Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE) |
1
2
3
11
UNS-L13910
UNS-L13890
UNS-L13840
UNS-L13870
Tin
90.0-92.0
88.0-90.0
83.0-85.0
86.0-89.0
Antimony
4.0-5.0
7.0-8.0
7.5-8.5
6.0-7.5
Lead
0.35
0.35
0.35
0.50
Copper
4.0-5.0
3.0-4.0
7.5-8.5
5.0-6.5
Iron
0.08
0.08
0.08
0.08
Arsenic
0.10
0.10
0.10
0.10
Bismuth
0.08
0.08
0.08
0.08
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
99.80
99.80
99.80
99.80
Chemical
Composition, %
Lead Base Babbitt
7
8
13
15
UNS-L53585
UNS-L53565
UNS-L53346
UNS-L53620
Tin
9.3-10.7
4.5-5.5
5.5-6.5
0.8-1.2
Antimony
14.0-16.0
14.0-16.0
9.5-10.5
14.5-17.5
Lead
remainder*
remainder*
remainder*
remainder*
Copper
0.50
0.50
0.50
0.6
Iron
0.10
0.10
0.10
0.10
Arsenic
0.30-0.60
0.30-0.60
0.25
0.8-1.4
Bismuth
0.10
0.10
0.10
0.10
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
Recycling Babbitt
