Page Revision: 2008/07/26 23:06
Babbitt was first created by Isaac Babbitt. Born July 26, 1799 in Taunton, Massachusetts, Babbitt was well known as an inventor by trade. In 1839, he received a patent for a white metal alloy that showed excellent bearing properties. The original formula for Babbitt's bearing metal was 89.3% tin, 7.1% antimony and 3.6% copper and that formula is still marketed today by some manufacturers as ASTE B23 Grade 2 Babbitt or as "Genuine Babbitt".
Types of Babbitt
Selecting a Type of Babbitt
Babbitt Classification
LIMITS |
Surface Speeds
(# of Ft/min) |
LOAD
(Lbs/sq.in.) |
MIN. |
MAX. |
MIN. |
MAX. |
Tin-Based Babbitts |
1,000 |
2,400 |
0 |
2,000 |
Lead Based Babbitts |
100 |
1,000 |
0 |
500 |
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Tin Based Babbitt
Recycling Babbitt
ASTM Babbitt Analysis Chart
ASTM B-23
Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE) |
1
2
3
11
UNS-L13910
UNS-L13890
UNS-L13840
UNS-L13870
Tin
90.0-92.0
88.0-90.0
83.0-85.0
86.0-89.0
Antimony
4.0-5.0
7.0-8.0
7.5-8.5
6.0-7.5
Lead
0.35
0.35
0.35
0.50
Copper
4.0-5.0
3.0-4.0
7.5-8.5
5.0-6.5
Iron
0.08
0.08
0.08
0.08
Arsenic
0.10
0.10
0.10
0.10
Bismuth
0.08
0.08
0.08
0.08
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
99.80
99.80
99.80
99.80
Chemical
Composition, %
Lead Base Babbitt
7
8
13
15
UNS-L53585
UNS-L53565
UNS-L53346
UNS-L53620
Tin
9.3-10.7
4.5-5.5
5.5-6.5
0.8-1.2
Antimony
14.0-16.0
14.0-16.0
9.5-10.5
14.5-17.5
Lead
remainder*
remainder*
remainder*
remainder*
Copper
0.50
0.50
0.50
0.6
Iron
0.10
0.10
0.10
0.10
Arsenic
0.30-0.60
0.30-0.60
0.25
0.8-1.4
Bismuth
0.10
0.10
0.10
0.10
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
