Page Revision: 2008/07/27 08:39
Babbitt was first created by Isaac Babbitt. Born July 26, 1799 in Taunton, Massachusetts, Babbitt was well known as an inventor by trade. In 1839, he received a patent for a white metal alloy that showed excellent bearing properties. The original formula for Babbitt's bearing metal was 89.3% tin, 7.1% antimony and 3.6% copper and that formula is still marketed today by some manufacturers as ASTM B-23 Grade 2 Babbitt or as "Genuine Babbitt". {Reference:http://www.frymetals.com/products/babbitt.html?product=babbitt|Fry Metals Babbitt Reference Guide}
Types of Babbitt
Selecting a Type of Babbitt
Babbitt Classification
LIMITS |
Surface Speeds
(# of Ft/min) |
LOAD
(Lbs/sq.in.) |
MIN. |
MAX. |
MIN. |
MAX. |
Tin-Based Babbitts |
1,000 |
2,400 |
0 |
2,000 |
Lead Based Babbitts |
100 |
1,000 |
0 |
500 |
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
The Load the bearing is required to carry is the weight which is being exerted through the combined weights of the shaft and any other direct weights on the shaft and measured in pounds per square inch. For most old wood working machines, the load on the bearings is not a major concern as the weight to surface area ratio is usually great enough to not be an issue. Load come more into play when you are using extremely heavy shafting over long stretches, such as in line-shaft applications where there is a lot of weight hanging on a couple of small bearings. Even though load will probably not bear into the decision making on the type of babbitt on most woodworking machines, it is still a good idea to calculate this value to be sure.
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Tin Based Babbitt
Recycling Babbitt
While the number of grades detailed by ASTM has changed over the years with fewer grades being standard today than before 1959, ASTM still recognizes eight grades of Babbitt. Here are the current standards for Babbitt metal by ASTM.
Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE) |
1
2
3
11
UNS-L13910
UNS-L13890
UNS-L13840
UNS-L13870
Tin
90.0-92.0
88.0-90.0
83.0-85.0
86.0-89.0
Antimony
4.0-5.0
7.0-8.0
7.5-8.5
6.0-7.5
Lead
0.35
0.35
0.35
0.50
Copper
4.0-5.0
3.0-4.0
7.5-8.5
5.0-6.5
Iron
0.08
0.08
0.08
0.08
Arsenic
0.10
0.10
0.10
0.10
Bismuth
0.08
0.08
0.08
0.08
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
99.80
99.80
99.80
99.80
Chemical
Composition, %
Lead Base Babbitt
7
8
13
15
UNS-L53585
UNS-L53565
UNS-L53346
UNS-L53620
Tin
9.3-10.7
4.5-5.5
5.5-6.5
0.8-1.2
Antimony
14.0-16.0
14.0-16.0
9.5-10.5
14.5-17.5
Lead
remainder*
remainder*
remainder*
remainder*
Copper
0.50
0.50
0.50
0.6
Iron
0.10
0.10
0.10
0.10
Arsenic
0.30-0.60
0.30-0.60
0.25
0.8-1.4
Bismuth
0.10
0.10
0.10
0.10
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
