Page Revision: 2010/09/15 09:36
While Babbitt metal is soft and can be easily damaged when treated improperly, and seems at first sight an unlikely candidate for a bearing surface, its appearance is deceptive. The structure of the alloy is made up of small hard crystals dispersed in a matrix of softer alloy. As the bearing wears the harder crystal is exposed, with the matrix eroding somewhat to provide a path for the lubricant between the high spots that provide the actual bearing surface.{Reference:http://www.frymetals.com/products/babbitt.html?product=babbitt|Fry Metals Babbitt Reference Guide}
How Babbitt Works
The principle as to how Babbitt works is really quite simple. In order for any bearing to work, it must create a situation where there is a low coefficient of friction. The lower the amount of friction on the rotating shaft, the easier it turns.
In the case of Babbitt bearings, this low coefficient of friction is accomplished by two means. First, the bearing material itself (the Babbitt) has a relatively low coefficient of friction. This means, even without lubrication, Babbitt bearings will have much less friction than if a shaft was turning in other metals such as steel or cast iron.
However, with the addition of simple lubrication, Babbitt bearings can have amazingly low coefficients of friction - even lower than that of ball bearings.
In order to achieve this low level of friction, bearings must be properly lubricated. Under ideal conditions, the motion of the rotating shaft over the babbitt surface will draw in whatever oil may be present, which builds up a thin film according to the laws governing the flow of fluids.
As an example of how this works, when the shaft is still and not rotating, the entire load of the shaft is making contact with the bearing surface. Ideally, at this point, there will be oil in the bearing, which will be surrounding the shaft on either side of the contact point.
As the shaft begins to turn, oil from around the bearing will be pulled under the rotating shaft until there is a wedged-shaped film of oil completely around the shaft. If conditions are right and adequate lubrication is present, the shaft will actually be floating on a thin film of oil and will not come in contact with the bearing material, resulting in an extremely low coefficient of friction.
 Fluid Film Lubrication |
If there is not enough oil to create this film of oil, or if once formed it breaks down due to insufficient speed, poor oil viscosity, insufficient oil or excessive load, there is usually enough oil present to wet the surfaces and prevent high friction coefficients. In this situation, it is not uncommon for the bearing to get warmer than one would like but this will usually not cause great problems.{Reference:The Elements of Machine Design. By S. J. Berard and E. O. Waters. Published by D. Van Nostrand Company, Inc., New York., Second Edition, 1932. Pp. 166-168}
Types of Babbitt
The term "Babbitt" is commonly used to describe any kind of "white metal" bearing material no matter the actual composition. Babbitt metals can generally be broken into two major families: tin based or lead based. Tin based Babbitt is the best choice for high speed or hard to lubricate bearings while lead based works best with low speed or heavy load bearings.{Reference:http://www.alchemycastings.com/lead-products/babbitt.htm|Alchemy Castings, Inc., Babbitt Metal}
Selecting a Type of Babbitt
To determine which bearing material would be best for your application, the following are suggested guidelines: {Reference:http://www.alchemycastings.com/lead-products/babbitt.htm|Alchemy Castings, Inc., Babbitt Metal}
Babbitt Classification
LIMITS |
Surface Speeds
(# of Ft/min) |
LOAD
(Lbs/sq.in.) |
MIN. |
MAX. |
MIN. |
MAX. |
Tin-Based Babbitts |
1,000 |
2,400 |
0 |
2,000 |
Lead Based Babbitts |
100 |
1,000 |
0 |
500 |
Calculate Surface Speed
Where:
Pi = 3.1416
RPM = Revolutions Per Minute
Calculate Bearing Load
The Load the bearing is required to carry is the weight which is being exerted through the combined weights of the shaft and any other direct weights on the shaft and measured in pounds per square inch.{Reference:http://www.alchemycastings.com/lead-products/babbitt.htm|Alchemy Castings, Inc., Babbitt Metal} For most old wood working machines, the load on the bearings is not a major concern as the weight to surface area ratio is usually great enough to not be an issue. Load comes more into play when you are using extremely heavy shafting over long stretches, such as in line-shaft applications where there is a lot of weight hanging on a couple of small bearings. Even though load will probably not bear into the decision making on the type of babbitt on most woodworking machines, it is still a good idea to calculate this value to be sure.
Bearing Load = W / ID x L
Where:
100 / 2 x 4 = 12.5 lbs/sq in
Lead Based Babbitt
Tin Based Babbitt
These materials are composed of 80 to 90% tin, with about 3 to 8% copper and 4 to 14% antimony added. An increase in the copper or antimony increases hardness and tensile strength and decreases ductility. Increasing the percentage of these hardening alloys above this range decreases both cracking resistance and fatigue strength according to the paper.
Recycling Babbitt
Chemical
Composition, %
Tin Base Babbitt Grades
ALLOY NUMBER (GRADE) |
1
2
3
11
UNS-L13910
UNS-L13890
UNS-L13840
UNS-L13870
Tin
90.0-92.0
88.0-90.0
83.0-85.0
86.0-89.0
Antimony
4.0-5.0
7.0-8.0
7.5-8.5
6.0-7.5
Lead
0.35
0.35
0.35
0.50
Copper
4.0-5.0
3.0-4.0
7.5-8.5
5.0-6.5
Iron
0.08
0.08
0.08
0.08
Arsenic
0.10
0.10
0.10
0.10
Bismuth
0.08
0.08
0.08
0.08
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
99.80
99.80
99.80
99.80
Chemical
Composition, %
Lead Base Babbitt
7
8
13
15
UNS-L53585
UNS-L53565
UNS-L53346
UNS-L53620
Tin
9.3-10.7
4.5-5.5
5.5-6.5
0.8-1.2
Antimony
14.0-16.0
14.0-16.0
9.5-10.5
14.5-17.5
Lead
remainder*
remainder*
remainder*
remainder*
Copper
0.50
0.50
0.50
0.6
Iron
0.10
0.10
0.10
0.10
Arsenic
0.30-0.60
0.30-0.60
0.25
0.8-1.4
Bismuth
0.10
0.10
0.10
0.10
Zinc
0.005
0.005
0.005
0.005
Aluminum
0.005
0.005
0.005
0.005
Cadmium
0.05
0.05
0.05
0.05
Total named
elements,
min
