Page Revision: 2008/04/06 16:59
Ray Munro and Kirk Poore posted a number of photos of jointer clamshell heads here http://owwm.org/viewtopic.php?t=28844
Here is a
Porter Style
cross section diagram of a slightly different clamshell, sold by Hall & Brown, contrasted with a square head
