Page Revision: 2008/04/06 18:40
Jeff Joslin provided a succinct summary of the problem with the clamshell design in a lengthy clamshell discussion here http://owwm.org/viewtopic.php?t=28823
The problem with a clamshell head is that the knives are directly held in place by the bolt heads. The faster the head spins, the higher the stress on the bolt heads. Hit a knot, and the impact transfers directly to the bolt heads. Now, are the bolts original, never been over-tightened, no stress cracks where the heads meet the stems, made of top-quality steel that was accurately machined and properly heat treated? If you are confident of good answers to all those questions, then your clamshell head should be plenty safe. Otherwise, you are taking chances. A wedge design is inherently safer because it is much less demanding on the components.
Cabinets2inlay added to Jeff's comments: Not only are the knives held in directly by the bolts, but the caps which pinch the knives are also held down by the bolts. The caps are heavy, and under the same forces as the knives. When a bolt fails, usually at one end, the cap bends, hitting the infeed table with considerable force. There are three such accidents mentioned on this site which happened within the last year. Do you have the kind of equipment that can evaluate the condition of the bolts? Do you know they have never been over-tightened? Are you sure you have all of them sufficiently tight? Are you sure that the bolts are tightening on the caps and not bottoming out in their holes? Unfortunately, clamshells are accidents waiting to happen. Some of us have used them for years, but statistically speaking, the longer you run one, the more chance there is of that accident happening.
Jeff Smith provided more information here http://owwm.org/viewtopic.php?t=29825 on bottoming out of the bolts on a cutterhead. One of the issues with a clamshell head is "bolt stretch" allowing the bolts that secure the blades to bottom out and giving one a false sense of tightness.
Ray Munro and Kirk Poore posted a number of photos of jointer clamshell heads here http://owwm.org/viewtopic.php?t=28844
Here is a
Porter Style
