Page Revision: 2008/04/06 23:13
[imageauto|The problem with a clamshell head is that the knives are directly held in place by the bolt heads. The faster the head spins, the higher the stress on the bolt heads. Hit a knot, and the impact transfers directly to the bolt heads. Now, are the bolts original, never been over-tightened, no stress cracks where the heads meet the stems, made of top-quality steel that was accurately machined and properly heat treated? If you are confident of good answers to all those questions, then your clamshell head should be plenty safe. Otherwise, you are taking chances.
 GetFile.aspx?File=PlanerClamshellHeads/4834-2.jpg |
Safety Issues
Do you have the kind of equipment that can evaluate the condition of the bolts? Do you know they have never been over-tightened? Are you sure you have all of them sufficiently tight? Are you sure that the bolts are tightening on the caps and not bottoming out in their holes? Unfortunately, clamshells are accidents waiting to happen. Some of us have used them for years, but statistically speaking, the longer you run one, the more chance there is of that accident happening.
One common cause of failure on clamshell heads is caused when the bolts bottom out in the cutterhead
source. Another issue with a clamshell head is "bolt stretch" allowing the bolts that secure the blades to bottom out and giving one a false sense of tightness.
Recent threads on the OWWM.org discussion forums concerning Clamshell failures are discussed here
http://owwm.org/viewtopic.php?t=22268
Clamshell Bolts
Another wide-ranging discussion of clamshell issues such as bolt head size, torque, use of loctite, etc. here
Source
