Page Revision: 2008/04/06 23:24
 Patent drawing of an early Clamshell design |
Safety Issues
Before trying to determine if a clamshell head is actually safe to use, you must first ask yourself several questions: # Do you have the kind of equipment that can evaluate the condition of the bolts?
sourceRecent threads on the OWWM.org discussion forums concerning Clamshell failures are discussed here
http://owwm.org/viewtopic.php?t=22268Another wide-ranging discussion of clamshell issues such as bolt head size, torque, use of loctite, etc. here
Source
