Page Revision: 2008/04/06 23:30
 Patent drawing of an early Clamshell design |
Safety Issues
sourceRecent threads on the OWWM.org discussion forums concerning Clamshell failures are discussed here
http://owwm.org/viewtopic.php?t=22268Another wide-ranging discussion of clamshell issues such as bolt head size, torque, use of loctite, etc. here
Source
