Page Revision: 2008/04/07 07:15
Many older jointers and planers utilized a style of cutterhead now known as "clamshell". A clamshell head head has two ore more steel or cast iron covers which bolt to the cutterhead to make the head "round". The covers in turn sandwiched the knives between the cover and the cutterhead, holding them in place.
Ironically, clamshell cuterheads were often referred to as "safety cutterheads" in old literature. The clamshell cutterhead was is part designed to replace the also dangerous square head which was bad about grabbing items (including arms and hands) and pulling them into the machine. With the theory that a round cutterhead would be less likely to pull a hand into the machine, it was dubbed a "safety head." Unfortunately, engineers at the time did not realize that the design was flawed and could lead to disaster when the clamshells failed. Because of safety issues, the clamshell style of cutterhead is no longer utilized by modern manufacturers.
 "Oliver" advertisment for their "Safety" cuterhead |
Safety Issues
sourceMore gory details of concerning Clamshell failures can be read in these threads on the OWWM Discussion Forums:
http://owwm.org/viewtopic.php?t=22268Another wide-ranging discussion of clamshell issues such as bolt head size, torque, use of loctite, etc. can be read in this
forum thread.
Examples of Clamshell Heads
Source
