Page Revision: 2008/04/06 23:11
Safety Issues
The problem with a clamshell head is that the knives are directly held in place by the bolt heads. The faster the head spins, the higher the stress on the bolt heads. Hit a knot, and the impact transfers directly to the bolt heads. Now, are the bolts original, never been over-tightened, no stress cracks where the heads meet the stems, made of top-quality steel that was accurately machined and properly heat treated? If you are confident of good answers to all those questions, then your clamshell head should be plenty safe. Otherwise, you are taking chances. Source
Not only are the knives held in directly by the bolts, but the caps which pinch the knives are also held down by the bolts. The caps are heavy, and under the same forces as the knives. When a bolt fails, usually at one end, the cap bends, hitting the infeed table with considerable force. To reinforce the dangers of clamshell heads, There have been at least three accidents mentioned on the OWWM forums in recent years.
Do you have the kind of equipment that can evaluate the condition of the bolts? Do you know they have never been over-tightened? Are you sure you have all of them sufficiently tight? Are you sure that the bolts are tightening on the caps and not bottoming out in their holes? Unfortunately, clamshells are accidents waiting to happen. Some of us have used them for years, but statistically speaking, the longer you run one, the more chance there is of that accident happening.
One common cause of failure on clamshell heads is caused when the bolts bottom out in the cutterhead source. Another issue with a clamshell head is "bolt stretch" allowing the bolts that secure the blades to bottom out and giving one a false sense of tightness.
Recent threads on the OWWM.org discussion forums concerning Clamshell failures are discussed here http://www.owwm.org/viewtopic.php?t=28690 and here http://owwm.org/viewtopic.php?t=22268
Clamshell Bolts
Examples of Clamshell Heads
Ray Munro and Kirk Poore posted a number of photos of jointer clamshell heads: Source
Here is a
Porter Style
