Page Revision: 2008/04/06 17:18
A wide-ranging discussion of clamshell issues such as bolt head size, torque, use of loctite, etc. here
http://owwm.org/viewtopic.php?t=31531
Ray Munro and Kirk Poore posted a number of photos of jointer clamshell heads here
http://owwm.org/viewtopic.php?t=28844
