Page Revision: 2008/04/07 21:56
Many older jointers and planers used a style of cutterhead now known as "clamshell". A clamshell head head has two or more steel or cast iron covers that bolt to the cutterhead to make the head "round". The covers in turn sandwich the knives between the cover and the cutterhead, holding them in place.
Ironically, clamshell cutterheads were often referred to as "safety cutterheads" in old literature. The clamshell cutterhead was is part designed to replace the also dangerous square head which was bad about grabbing items (including arms and hands) and pulling them into the machine. With the theory that a round cutterhead would be less likely to pull a hand into the machine, it was dubbed a "safety head." Unfortunately, engineers at the time did not realize that the design was flawed and could lead to disaster when the clamshells failed. Because of safety issues, the clamshell style of cutterhead is no longer used by modern manufacturers.
 Oliver advertisment for their "Safety" cutterhead |
Safety Issues
The problem with a clamshell head is that the knives are directly held in place by the bolt heads. The faster the head spins, the higher the stress on the bolt heads. Hit a knot, and the impact transfers directly to the bolt heads. Now, are the bolts original, never been over-tightened, no stress cracks where the heads meet the stems, made of top-quality steel that was accurately machined and properly heat treated? If you are confident of good answers to all those questions, then your clamshell head should be plenty safe. Otherwise, you are taking chances. {Reference:http://owwm.org/viewtopic.php?t=28823|http://owwm.org/viewtopic.php?t=28823}
Not only are the knives held in directly by the bolts, but the caps that pinch the knives are also held down by the bolts. The caps are heavy, and under the same forces as the knives. When a bolt fails, usually at one end, the cap bends, hitting the infeed table with considerable force. To reinforce the dangers of clamshell heads, there have been at least three accidents mentioned on the OWWM forums in recent years.
One common cause of failure on clamshell heads is caused when the bolts bottom out in the cutterhead. Very often, with years of stress caused by repeated tightening of the bolt as well as centrifugal stresses from high speed spinning, the bolts will "stretch," causing the bolts that sandwich the blades between the cutterhead and the clamshell to bottom out, giving one a false sense of tightness.{Reference:http://owwm.org/viewtopic.php?t=29825|http://owwm.org/viewtopic.php?t=29825}
More gory details of concerning Clamshell failures can be read in these threads on the OWWM Discussion Forums:
http://owwm.org/viewtopic.php?t=22268Another wide-ranging discussion of clamshell issues such as bolt head size, torque, use of Loctite, etc. can be read in this
forum thread.
Examples of Clamshell Heads
Ray Munro and Kirk Poore posted a number of photos of jointer clamshell heads:{Reference:http://owwm.org/viewtopic.php?t=28844|http://owwm.org/viewtopic.php?t=28844}
Oliver Safety Cylinder
Side view showing the cap. Oliver clamshell is on the left (wood filler substituting for the knife). SCMI replacement head on the right (with knives in backwards)
A square head that is set up to use thin (non slotted knives) with knife caps. The knives are retained by the cap, not the bolts directly. Could be called a "clamshell" I guess.
Stutzman Head
Porter Style "A" Safety Cyliinder
Hall & Brown Clamshell
