Page Revision: 2008/04/06 22:59
Safety Issues
Do you have the kind of equipment that can evaluate the condition of the bolts? Do you know they have never been over-tightened? Are you sure you have all of them sufficiently tight? Are you sure that the bolts are tightening on the caps and not bottoming out in their holes? Unfortunately, clamshells are accidents waiting to happen. Some of us have used them for years, but statistically speaking, the longer you run one, the more chance there is of that accident happening.
Jeff Smith provided more information here
http://owwm.org/viewtopic.php?t=29825 on bottoming out of the bolts on a cutterhead. One of the issues with a clamshell head is "bolt stretch" allowing the bolts that secure the blades to bottom out and giving one a false sense of tightness.
Clamshell disasters are discussed here
http://owwm.org/viewtopic.php?t=22268
Clamshell Bolts
Another wide-ranging discussion of clamshell issues such as bolt head size, torque, use of loctite, etc. here
Ray Munro and Kirk Poore posted a number of photos of jointer clamshell heads here
http://owwm.org/viewtopic.php?t=28844
