Page History: Crescent Heavy 8-inch Jointer
Page Revision: 2008/09/25 16:39
1903 Catalog
Crescent 8-inch Jointer
Length of tables  Front. 83; rear 30 inches.
Height of table from floor.  33 inches.
Floor space required, over all  21x64 inches.
Cubic measure, boxed for export  24 feet.
Gross weight, boxed for export  1,000 pounds.
Net weight  800 pounds.
List price of machine  $130
Telegraphic code word  Ennoergie.
