Page History: DeWalt MBF & MBC Motor Bearing Replacement
Page Revision: 2008/03/29 14:52
A Japanese JAF 88500 was used to replace the Fafnir 200KLL2 on the cord side and a Japanese IKS 88504 to replace the New Departure C 88504 on the arbor side. These bearings were ordered from
http://accuratebearing.com/ Accurate Bearing and are fairly standard.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF08.jpgThe circular plate with the four slotted screws came off next. This plate screws to a similar plate inside that holds the bearing in the end bell.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF12.jpgWith the bolts out, the end bells rotate freely. Of course you don't want to get wild with the cord-side, but the arbor-side is fair game.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF13.jpgAllowing everything else to come out as an assembly:
http://www.wiki.owwm.com/attachments/images/DeWaltMBF18.jpgA two-arm puller was used to persuade the end bell off of the bearing. Again, not much resistance:
http://www.wiki.owwm.com/attachments/images/DeWaltMBF20.jpgThere is a snap ring holding the arbor side bearing in place. Work it off of the shaft, then prepare to remove the bearing.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF23.jpgYour options are somewhat limited here as the fan and the retaining ring leave very little clearance behind the bearing. One option that was suggested would be to take two threaded rods, screw them into the bearing retaining plate and use a bar puller to get the bearing off.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF26.jpgThe parallels are bearing against the ID of the fan. I've seen many reports of these fans breaking upon removal, so be careful here.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF17.jpgNext came the cord-side bearing:
http://www.wiki.owwm.com/attachments/images/DeWaltMBF28.jpgThe shaft where this bearing is installed is stepped/tapered, which doesn't expose much of the ID of the bearing. The setup that I used destroyed the bearing, but it came off cleanly. With a proper bearing splitter, pulling it without damage may have been possible.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF29.jpg
http://www.wiki.owwm.com/attachments/images/DeWaltMBF31.jpgTo get the arbor-side bearing back in the end bell, I warmed up the end bell under a lamp for a while. The bearing almost fell in place.
http://www.wiki.owwm.com/attachments/images/DeWaltMBF35.jpgThis really doesn't take much force, but putting everything in the press prevents racking and keeps everything nice and straight.
From owwm.org thread:
http://owwm.org/viewtopic.php?t=30990
