Page History: DeWalt MBF & MBC Motor Bearing Replacement
Page Revision: 2008/03/29 18:07
A Japanese JAF 88500 was used to replace the Fafnir 200KLL2 on the cord side and a Japanese IKS 88504 to replace the New Departure C 88504 on the arbor side. These bearings were ordered from
Accurate Bearing and are fairly standard.
From owwm.org thread:
http://owwm.org/viewtopic.php?t=30990
