Page History: OWWM decals
Page Revision: 2010/01/11 23:32
Arcade
The Arcade Manufacturing Co. - Submitted by Bob Holcombe
Atlas Press Company
The Atlas Press Co. - Submitted by Bob Holcombe
A V Carroll
Red Fox
Red Fox
Red Fox
Red Fox
Red Fox
Red Fox
submitted by Treetrimmer 6 (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
submitted by caesars0331 (original by Andrew Mingione. for personal use only) (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
Boice-Crane Oscillating Spindle Sander
Submitted by Box Maker (Mark Thompson)
submitted by Phewop (Right click and select "save target as" to download High-res version)
Boice-Crane Power Tools - Submitted by Andrew Mingione . For personal use only.
Boice-Crane Power Tools - Submitted by Andrew Mingione. For personal use only.
Buffalo Forge / Black
Canadian Buffalo Forge
Canadian Buffalo Forge - Submitted by Treetrimmer
Canadian Buffalo - Submitted by Andrew Mingione . For personal use only.
Canadian Buffalo - Submitted by Andrew Mingione. For personal use only.
Buffalo - Submitted by Andrew Mingione>. For personal use only.
Companion
Companion
Companion
submitted by Treetrimmer 6 (Right click and select "save target as" to download High-res version)
Craftsman / Blue Badge
Craftsman Bearing. Submitted by cbdeajr
((Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
This one comes from a Craftsman bench top DP (101.03580) manufactured by Atlas Press. I wouldn't be surprised if this decal appears on other machines. Submitted by NeilB
Craftsman / Planer Submitted by NeilB
Craftsman Highest Quality
Delta / Marathon Motor Tag
Delta / 10
Delta / 10" Bandsaw
Delta / 14
Delta / 14" Bandsaw
Submitted by NeilB.
Submitted by NeilB.
Delta Triple Duty Grinder 1
Delta Triple Duty Grinder 2
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Delta Milwaukee Power Tools Division - Submitted by Andrew Mingione . For personal use only.
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Delta Quality Tools Label
Delta / 654 Jointer Decal
Submitted by Girino
Submitted by Girino
Delta 1948 Scroll Saw
Delta Important
Delta Important
Rockwell Small Decal 1
Rockwell Small Decal 1"
Rockwell Switch Plate Decal
Delta 15
Delta 15" Drill Press Logo
Rockwell/Delta Patent Number Decal from 37-220 6
Rockwell/Delta Patent Number Decal from 37-220 6" Jointer ca.1965
Rockwell LVC
DeWalt logo - Submitted by Andrew Mingione . For personal use only.
DeWalt logo - Submitted by Andrew Mingione. For personal use only.
Old style DeWalt - Submitted by Bob Holcombe
AMS Dewalt Badge - Submitted by Darren Carter
AMF DeWalt Table Badge - Submitted by Kent Johnson. PM me if you need the vectored version.
(Right click and select "save target as" to download High-res version)]
Delta Quality Tools Label - Submitted by Phewop
Dunlap
Dunlap
Dunlap
Goodell-Pratt
Submitted by NeilB
Submitted by NeilB
Herberts Machinery Company
Wood Wizard - Submitted by Andrew Mingione . For personal use only.
Wood Wizard - Submitted by Andrew Mingione. For personal use only.
Heston and Anderson
Heston and Anderson - Submitted by Bob Holcombe
Heston and Anderson Black/Gold - Submitted by phewop
Heston / Anderson Submitted by Phewop
K-Line
The Kneisley Electric Company - Submitted by Bob Holcombe
Power King
The Power King Tool Corp Co. - Submitted by Bob Holcombe
The Power King Tool Corp Co. Version 2- Submitted by Phewop
Powr-Kraft
Powr-Kraft - Submitted by Bob Holcombe
Powermatic
[imageleft|Powermatic - Submitted by Cromulentone|GetFile.aspx?File=Decals/thumbnails/powermaticthumb.png|GetFile.aspx?File=Decals/powermatic logo 11-23.png}
Unknown
Unknown - Submitted by Unknown
Unknown - Submitted by 'Unknown'
Walker-Turner Power Tools - Submitted by Andrew Mingione . For personal use only.
Walker-Turner Power Tools - Submitted by Andrew Mingione. For personal use only.
The Driver Line - Submitted by Bob Holcombe
Walker-Turner badge: Black - Submitted by Andrew Mingione . For personal use only.
Walker-Turner badge: Black - Submitted by Andrew Mingione. For personal use only.
Walker-Turner Motor Tag - Submitted by Doug Bliven
Yates American Decals
Yates - Submitted by AccountingTroll
art restoration by Treetrimmer 6 (Right click and select "save target as" to download High-res version)
Bearings decal - Submitted by Darnell Hagen
