Page Revision: 2013/08/01 11:19
The entry looks like this:
Delta Mfg. Co.
Delta / Marathon Motor Tag
submitted by
submitted by
Delta / 14" Bandsaw
Submitted by NeilB.
Delta Triple Duty Grinder 1
Delta Triple Duty Grinder 2
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Submitted by NeilB
Delta Quality Tools Label
Delta / 654 Jointer Decal
Delta 1948 Scroll Saw
Delta Important
9Right click and select, in IE "Save Target As", in Firefox "Save Link As")
