Page Revision: 2017/10/13 02:39
Sheet metal cut out
Sheet metal cut out
Elbow test fit to funnel
Elbow and exit duct installed
Funnel installed
Funnel installed
Funnel installed
Funnel installed
Download printable PDF of pattern: PDF of Delta Unisaw Dust Collection Funnel Pattern
