Page Revision: 2020/03/16 12:10
This is one solution for dust collection on a Delta 10" Unisaw. This funnel is my design and creation as a solution for my 1946 Delta Unisaw. It works very well for me, but there are other solutions out there.
The funnel is made to fit the inside of the Unisaw cabinet closely. The vertical seams on the inside of the cabinet prevent the funnel from touching the walls of the cabinet. This small gap can be closed by either make the funnel a little larger and cutting slots in the edges to accommodate the vertical cabinet seams, or by filling the gap with something such as foam.
So far, I haven't found the small gap to be a big enough issue to require solving. I had some carpet padding lying around, so I used thin strips of that to close the gap between the outer edge of the funnel and the inside wall of the cabinet. It only took a minute and prevents virtually all the sawdust from bypassing the funnel.
Funnel installed
