Page Revision: 2020/03/16 12:04
The funnel is made to fit the inside of the Unisaw cabinet closely. The vertical seams on the inside of the cabinet prevent the funnel from touching the walls of the cabinet. This small gap can be closed by either make the funnel a little larger and cutting slots in the edges to accommodate the vertical cabinet seams, or by filling the gap with something such as foam. So far, I haven't found the small gap to be a big enough issue to require solving. I had some carpet padding lying around, so I used thin strips of that to close the gap. It only took a minute and prevents virtually all the sawdust from bypassing the funnel.
Sheet metal cut out
Elbow test fit to funnel
Elbow and exit duct installed
Funnel installed
Funnel installed
Funnel installed
