Page Revision: 2009/04/22 08:42
IN PROGRESSTop Drum Cover
From Bob Vaughan:
Fitting Newer Covers
Newer top covers won't usually fit earlier sanders without some modifications being made{Reference:http://owwm.org/viewtopic.php?t=25277|6X48 complete, have an issue}:
Side Cover
From Bob Vaughan:
Lower Drum Cover
The lower drum covers also differ between newer and older sanders:
See the link below for Jamie Norwood's solution to the problem.
See Also
