Page Revision: 2009/04/25 01:23
IN PROGRESS
Top Drum Cover
Fitting Newer Covers
Newer top covers won't usually fit earlier sanders without some modifications being made{Reference:http://owwm.org/viewtopic.php?t=25277|6X48 complete, have an issue}{Reference:http://owwm.org/viewtopic.php?t=11191|Delta 6" x 48" belt sander}:
Note also that new/old top covers won't work properly with old/new side covers. The shape of the bump-out where they meet is a different shape. The newer ones have a straighter side to the bump-out.{Reference:http://owwm.org/viewtopic.php?t=50230|Pics! Delta 6" Belt 12"DiskSander #31-730 for $100}
Side Cover
From Bob Vaughan:
An alternate approach by Bob Vaughan.{Reference:http://www.owwm.org/viewtopic.php?t=41918|Delta 6x48 31-730 sander repair details(16 pictures)} A couple of holes were punched in the edge of the cover, then the casting was drilled at tapped 10-24 so the side cover would be held on by screws and not the grooves in the dust collection casting.
Lower Drum Cover
Comparison
The lower drum covers also differ between newer and older sanders. The newer style will not fit older sanders.
See the links section below for Jamie Norwood's solution to the problem.
Deflector Plate
Shane Whitlock's sander was missing the deflector plate{Reference:http://owwm.org/viewtopic.php?t=49974|Rockwell Belt Sander Restoration pictures (updated all finished)}:
Keith Bohn provided these reference images:
Shane fabricated a deflector plate from 20 gauge paintlock:
See Also
