Page Revision: 2009/04/24 22:07
By Bob VaughanOutside ends of worn drums:
Inside of worn drums:
Additional images of the usual W-shaped drums:
[image| |GetFile.aspx?File=PM30/31bcopy.jpg
Re-Crowning Drums
Turning on a Lathe
By Bob Vaughan{Reference:http://owwm.org/viewtopic.php?t=41577|Worn drum on 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=41720|PM 30 sander belt tracking blues}I'll put the shaft in the lathe, then put on both drums with needed spacers, then turn both drums at the same time using the compound over at some slight angle like 1º or so per side, giving a slight V crown rather than a round one. The angle will likely dictated by the thickness of the drum. When I re-crown, its a matter of reacting to the geometry of whatever's in front of me.The big thing is to get rid of that upturn profile on the outer edges. Its those outer edge diameters that makes tracking impossible under load. Below is an idler drum restored on the lathe.
Tracking is great now.
'By
Bob Vaughan''{Reference:http://www.owwm.org/viewtopic.php?t=47121|Powermatic 30 sander restoration, belt won't track straight}
Redneck machine shop job:
- Install on machine.
