Page Revision: 2009/04/24 00:59
Examples from Bob Vaughan.
Outside ends of worn drums:
Inside of worn drums:
Re-Crowning Drums
Turning on a Lathe
By Bob VaughanI'll put the shaft in the lathe, then put on both drums with needed spacers, then turn both drums at the same time using the compound over at some slight angle like 1ยบ or so per side, giving a slight V crown rather than a round one. The big thing is to get rid of that upturn profile on the outer edges. Its those outer edge diameters that makes tracking impossible under load. Below is an idler drum restored on the lathe.
Tracking is great now.
