Page Revision: 2009/04/22 09:15
IN PROGRESS
Repair
Machining or Grinding Flat
It is possible to repair a worn cast iron platen by machining or grinding it flat{Reference:http://owwm.org/viewtopic.php?t=27688|A Delta 6 X 48 Cast Iron Platen Reborn!}. The thickness of metal that will remain afterwards should be taken into consideration before choosing this option. Below are images from Bruce Erdman showing a platen with typical wear and the results after Blanchard grinding:
Flattening With Filler
Flattening On The Machine
Next I took a new belt and turned it inside out and put it on the sander. I found a flat piece of OSB, turned on the sander and pressed the OSB firmly against the belt which sanded the J.B. weld down until the face of the platen was nice and flat. It took a while to flatten it out but it worked great. It helped to have my wife turned the tracking screw in and out so the belt moved side to side across the platen while sanding.
Graphited Canvas
Applying graphited canvas is reported to result in a cooler running belt, less load on the motor and provide inexpensive, easy to replace protection to a newly flattened platen. FORMATTER ERROR (":" and "&" not supported in Page Names)
See Also
