Page Revision: 2018/04/21 18:05
Repair
Machining or Grinding Flat
It is possible to repair a worn cast iron platen by machining or grinding it flat
A Delta 6 X 48 Cast Iron Platen Reborn!
Worn drum on 6x48 sander
The thickness of metal that will remain afterwards should be taken into consideration before choosing this option. Below are images from Bruce Erdman showing a platen with typical wear and the results after Blanchard grinding:
Flattening With Filler
On The Machine
Graphited Canvas
Applying graphited canvas is reported to result in a cooler running belt, less load on the motor and provide inexpensive, easy to replace protection to a newly flattened platen.{Reference:http://owwm.org/viewtopic.php?t=41577|Worn drum on 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=36170|machining a 6x48 belt sander platen}
Setting the Platen
See Also
