Page Revision: 2009/04/24 00:01
Do not follow the below image yet, you may break the casting. More description to come.WARNING: Read this whole section before proceeding with removal of the upper shaft. It is not uncommon to break the idler arm casting as seen below{Reference:http://owwm.org/viewtopic.php?t=15145|Removing spindle from Delta 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=15318| Removing spindle from Delta 6x48 sander.. continued}.
A press is recommended, if not fully required. The clamshell drum halves are a slip fit and should just slide off. Old ones rarely, if ever, do that. The steel shaft sometimes galvanic welds to the drums, requiring significant extra pressure to break the bond.{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
==Examples of Shafts and Conditions==
Shaft Fabrication
Shaft fabrication is easy with a metal lathe. Take 15mm ground rod (see links below for source) and thread the ends to fit the fine nuts you have. Newer shafts have different threads to older ones (see pictures above).{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
- MSC Search for "15mm drill rod"
