Page Revision: 2009/04/24 01:39
IN PROGRESS
Removing Upper Shaft
{Reference:http://owwm.org/viewtopic.php?t=15145|Removing spindle from Delta 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=15318| Removing spindle from Delta 6x48 sander.. continued}{Reference:http://owwm.org/viewtopic.php?t=41911|Rockwell 6x48 Belt Sander Bearings}
A press is recommended, if not fully required. Pounding on the shaft is unlikely to move it. The clamshell drum halves are a slip fit and should just slide off but old ones rarely, if ever, do that. The steel shaft sometimes galvanic welds to the drums, requiring significant extra pressure to break the bond.{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
Comparisons to Powermatic 30
Shaft Fabrication
