Page Revision: 2009/04/24 23:20
{Reference:http://owwm.org/viewtopic.php?t=15145|Removing spindle from Delta 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=15318| Removing spindle from Delta 6x48 sander.. continued}{Reference:http://owwm.org/viewtopic.php?t=41911|Rockwell 6x48 Belt Sander Bearings}{Reference:http://owwm.org/viewtopic.php?t=50397|Delta sander 31-710 bearing removal}{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}
- Add additional support for the casting so it does not bend down. The challenge with this technique is that the casting may end up taking all the load, in which case it will certainly break.
- A technique that has been used on a similar bearing setup on a different machine is to first remove the balls from the lower bearing: pop off the seal, drill and pry out the bearing cage, move all the balls to one side, then pop them out. Now the shaft will be free to come out without applying any pressure to the bottom of the casting. Ensure that the inner race is not catching on the outer race before applying full pressure.
Comparisons to Powermatic 30
Shaft Fabrication
Shaft fabrication is easy with a metal lathe. Take 15mm ground rod (see links below for source) and thread the ends to fit the fine nuts you have. Newer shafts have different threads to older ones (see pictures above).{Reference:http://owwm.org/viewtopic.php?t=8411|Rockwell 6x48 sander}{Reference:http://owwm.org/viewtopic.php?t=27705|Delta 6x48 upper (idler) shaft question?}{Reference:http://www.owwm.org/viewtopic.php?t=41918|Delta 6x48 31-730 sander repair details(16 pictures)}
