Page Revision: 2009/04/24 22:36
IN PROGRESSTables
Comparison
The photo below from Bob Vaughan compares a table and trunnion from a late model disc/belt sander (left) with the older style (right). Note the repaired break on the late model trunnion, a common point of failure on the newer part.{Reference:http://owwm.org/viewtopic.php?t=50230|Pics! Delta 6" Belt 12"DiskSander #31-730 for $100}
Table Lip Repair
By Shane Whitlock{Reference:http://owwm.org/viewtopic.php?t=49974|Rockwell Belt Sander Restoration Pics (updated all finished)}. The edge of the table was really chewed up and I wasn't sure how I was going to fix it. I could have just cut the edge off but then it would have had about a 1/2" gap between the table and sander. I thought about mounting a piece of steel to the top but then I couldn't use the miter gauge.
Stops
