Page Revision: 2008/04/05 11:25
Early Band Saws in the OWWM Archives: A Research Paper in Eight Parts¶
Part 1. Patent dates and four footed cast iron, cast iron wheeled band saws¶
Welch & Chipman saw
Welch, Harrison & Co. saw
C.B. Rogers & Co saw
June 16, 1868 cast into them, and, therefore both saws were manufactured after that date. The four Pryibil related saws have several patent dates attached or cast onto them, as follows:
May 26, 1874. Therefore this saw could not have been manufactured prior to that time.
| Welch, Harrison | after June 16, 1868 |
| Welch & Chipman | after June 16, 1868 |
| First & Pryibil (Steere example) | after January, 1873 |
| Pryibil (Poore example) | after January, 1873 |
| Pryibil (Barnhart example) | after January, 1873 |
| Collins & Greenwood | after August 12, 1873 |
| D.C. Allen | after May 26, 1874 |
| First & Pryibil ('Woodshave' example) | after 1876 |
| D. C. Allen | Concord NH |
| Collins & Greenwood | Lebanon NH |
| C.B. Rogers & Co. | Norwich CT |
| Welch & Chipmam | South Boston MA |
| Welch, Harrison & Co. | South Boston MA |
| First & Pryibil (2 examples) | New York NY |
Part 2. Patent Dates and other early band saws that are non four footed, but are cast iron and do not have fully cast iron wheels¶
- Atlantic Works (5 examples)
- J.A. Fay & Co. (3 examples)
- Goodell & Waters (2 examples)
- L. Power & Co. (2 examples)
- Baxter D. Whitney (1 example)
- Atlantic Works (Hanson example) last date 1873
- Atlantic Works (Potts example L.B & O) last date 1871
- Atlantic Works (Streff example) no record of patent mark
- Atlantic Works (Potts no. 2 example B & O) no record of patent mark
- Atlantic Works (Gee example L.B. & O) last date 1871
- J.A. Fay & Co. (Buck example) last date 1874
- J.A. Fay & Co. (Haire example) last date 1874
- J.A. Fay & Co. example? last date 1874
- Goodell & Waters (Thomas example) no record of patent mark
- Goodell & Waters (Fisher example) said to be 1882
- L. Power & Co. (Bernstein example) no record of patent mark
- L. Power & Co. (Potts example) no record of patent mark
- Baxter D. Whitney no record of patent mark
- J.A. Fay & Co. (as Page & Co.) 1834 (as J.A. Fay & Co.) prior to 1850
- Baxter D. Whitney (circa 1837)
- L. Power & Co. (circa 1867)
- Goodell & Waters (as Goodell, Braun & Co.) prior to 1869 (as Goodell & Waters) circa 1873 or 1874
- Atlantic Works (as Richards, Kelley, & Co.) 1870
Part 3. Comparison of earliest (i.e. not latest) patent dates of early band saws¶
| J.A. Fay & Co. (Haire example) | Reissued Aug. 25. 1865, Pat June 16.1868, Sept. 1. Nov. 1. 1871, May 21. 1872, May 19. 1874. |
| First & Pryibil ('Woodshave' example) | said to be 1876 (prob '1866) |
| Pryibil (Poore example) | 'Pat Aug 28 1866 & Jan 73' |
| Pryibil (Barnhart example) | 'Pat 1866 & 73' |
| Welch, Harrison | June 16, 1868 |
| Welch & Chipmam | June 16, 1868 |
| J.A. Fay & Co. (Buck example) | June 16, 1868, Sept 19, 1871, Nov. 14, 1871, May 21, 1872, May 19,1874 |
| First & Pryibil (Steere example) | Aug 28, 1868 & Jan 1873 |
| Atlantic Works (Potts example L.B & O) | June 7, 1870, Jun. 28, 1870, Apr. 25, 1871, May 9, 1871 |
| Atlantic Works (Gee example) | June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871 |
| Atlantic Works (Hanson example) | June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871 |
| J.A. Fay & Co. (? example) | May 19, 1874 (only date recorded may be others?) |
| Goodell & Waters (Fisher example) | said to be 1882 |
- Reissued Aug. 25. 1865
- Pat June16, 1868,
- Sept. 1 Nov. 1 1871,
- May 21, 1872,
- May 19, 1874.
| Reissued Aug. 25. 1865 | no J.A. Fay & Co patent this date |
| Pat June16, 1868 | Improvement in guides for bandsaws |
| Sept. 1 Nov. 1 1871 | no J.A. Fay & Co patent these dates |
| May 21, 1872 | Improvement in pulleys for bandsaws |
| May 19, 1874 | Improvement in band sawing machines |
Part 4. Comparison of patent dates between four footed cast iron, cast iron wheeled band saws and early band saws that are not four footed, are cast iron with, generally, non-cast iron wheels¶
| Jun. 16, 1868 | J.A. Fay | John Lemman |
| Jun. 7, 1870 | Atlantic Works | John Richards |
| Jun. 28, 1870 | Atlantic Works | William H. Thorne |
| Apr. 25, 1871 | Atlantic Works | John Richards |
| Sep. 19, 1871 | J.A. Fay | William H. Doane |
| Nov. 14, 1871 | J.A. Fay | William P. McKee? |
| May. 7, 1872 | Baxter D. Whitney | Baxter D. Whitney |
| May. 14, 1872 | Baxter D. Whitney | Baxter D. Whitney |
| May. 21, 1872 | J.A. Fay | William H. Doane |
| Apr. 8, 1873 | Baxter D. Whitney | Baxter D. Whitney |
| May. 19, 1874 | J.A. Fay | William P. McKee? |
| Jul. 13, 1875 | Baxter D. Whitney | Baxter D. Whitney |
| Aug. 14, 1877 | J.A. Fay | George W. Bugbee |
| Mar. 19, 1878 | J.A. Fay | Francis Clark |
| Sep. 4, 1883 | Goodell & Waters | William G. Vernon |
| Aug. 26, 1884 | Goodell & Waters | Louis T. Pyott |
| Sep. 1, 1885 | L. Power | Louis T. Pyott |
| 1837 | Baxter D. Whitney |
| 1847 | J.A. Fay |
| 1867 | L. Power |
| c. 1869 | Goodell & Waters |
| c. 1869 | Atlantic Works |
