Page Revision: 2008/04/09 16:24
Grease for Machinery
Introduction to Grease
All greases start with an oil base stock and then add thickeners. The most common base is an ISO-220 stabilized oil. The most popular thickeners are metallic "soaps". Some of them are lithium, calcium, molybdenum, and boron. The metallic particles are made into a soap through a process call "saponification". Other thickeners used are microgel clays and polyurea, which are usually for specialized applications. NLGI (National Lubricating Grease Institute) is the most common classification system in use today. Grease thickness grades are from an NLGI of "000" which is pourable to a "6" which comes in brick form. NLGI grades do not overlap and there are companies that offer some greases in half grades ( NLGI 1.5). There is also an NLGI service classification that was developed for the automotive industry. Supposedly, they are working at an industrial equivalent to ASTM D-4950 which is the automotive standard.
Almost all of the "gun grease" is an NLGI #2. Lower numbered greases are used in gear boxes, central lube systems, and cartridge spindle assemblies. There are reasons for thinner greases and most of them are very valid. Just because a machine has a zerk on it, does not mean it takes #2! The manual is still the best place to look (assuming you can find one!) {Reference:http://owwm.org/viewtopic.php?t=31028|http://owwm.org/viewtopic.php?t=31028}
Grease Selection
For grease it seems that picking your favorite NLGI 1 grease should do. If you are starting fresh a synthetic NLGI 1 grease might be a good choice, in my opinion. If you are adding grease to a machine with an unknown lubrication history it’s a bit trickier. The consensus is that there is no known universally compatible grease, many grease types are incompatible with each other, and on an old machine, you usually have no idea what was used in the past. Mixing incompatible greases can soften one or both of the greases. Does this matter? Might. Ideal is to start with a clean, non-greased bearing. {Reference:http://owwm.org/viewtopic.php?t=31145|http://owwm.org/viewtopic.php?t=31145}
Chevron SRI grease is used/recommended by just about all motor manufacturers for ball bearing use. HOWEVER, since Chevron SRI is a Polyurea based grease, it can have compatibility problems with other greases. Industry recommends flushing out all old grease before re-greasing with a polyurea (Chevron CRI) grease. As to how much to add, most motors are OVER greased. One or two "shots" from a grease gun is all (about 2 teaspoons). Once a year greasing is way more than most applications need. Example, for new motors, Baldor recommends greasing motor bearings every 5,000 hours of operation (3600rpm) or 12,000 hours (1800rpm). At work, a belt driven, 15hp blower motor that runs 24/7 is greased just once a year. Motor has been in service 6+ years now no failure (~48,000 hours of use). I disagree with adding grease until it comes out when greasing a
motor. Bob is right about removing the drain plug but, most (including maint. crew at work) don't bother to remove the drain plug to allow excess grease out. With new motors there is plenty of empty room and no grease will come out of the drain for many greasings. OVER GREASING damages more MOTORS than under greasing. {Reference:http://owwm.org/viewtopic.php?t=4464|http://owwm.org/viewtopic.php?t=4464}
Oil for Machinery
| Velocite #6 | ISO - 10 | |
| Velocite #10 | ISO -22 | |
Other recommendations seem less clear. For example, for Oliver machines with open, oil bath bearings, speeds < 4,000 rpm, Dev and others have recommended DTE light or Vactra #1, both ISO 32 oils. Oliver literature recommends Vactra heavy medium oil. Vactra heavy medium oil seems to translates to Vactra #2 an ISO of 68. This comes from the Mobil literature and the PM site. I’m using Vactra #2 for my 116d and 166.{Reference:http://owwm.org/viewtopic.php?t=31145|http://owwm.org/viewtopic.php?t=31145}
Additional Topics Needed in this Wiki
Requests have been made in the forums for additional information relating to grease and lubrication. Others with more knowledge are encouraged to update this wiki to help answer these questions.
- drill press spindles
- drill press rack
- machine ways
- variable speed pulleys
- drip rates
- exchange frequency
- capacities
