Page Revision: 2008/03/30 17:26
| INDUSTRIAL ENAMEL | ALKYD |
| GLOSS | IFC 411X |
| BAC COLORANT | OZ | 32 | 64 | 128 |
| B1- Black | 4 | 7 | 1 | 1 |
| Y3- Deep Gold | - | 4 | 1 | 1 |
DEEP BASE
Quantity: 1 QUART
Keith O'Boyle, Nov 21, 2007
