Page Revision: 2009/04/07 20:53
-Curt Blank April 7th, 2009
INDUSTRIAL ENAMELALKYD
GLOSSIFC 411X
BAC COLORANTOZ3264128
B1- Black4711
Y3- Deep Gold-411
DEEP BASE
Quantity: 1 QUART
Keith O'Boyle, Nov 21, 2007
