Page Revision: 2008/03/30 17:30
INDUSTRIAL ENAMELALKYD
GLOSSIFC 411X
BAC COLORANTOZ3264128
B1- Black4711
Y3- Deep Gold-411
DEEP BASE
Quantity: 1 QUART
Keith O'Boyle, Nov 21, 2007
