Page Revision: 2009/02/10 15:25
Format | Years | Comments |
| 1948 to 1953 | Early machines did not have serial numbers. |
mnnn | 1953 to 1955 | "m" is a digit that varied according to machine type. "nnn" is the number of the machine within this series. |
N-nnnn | 1955 to 1964 | "N" is the unit digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
6N-nnnn | 1965 to 1968 | "N" is the unit digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
NMM-nnnn | 1968 to 1977 | "N" is the unit digit of the year, beginning in 1968. |
NNMM-nnnn | 1968 to ???? | "NN" is the last two digits of the year, beginning in 1978. |
The above table provides general guidelines but if you should double-check against the detailed tables below.
Single-End Tenoners
| | Model 2 |
| 1948 to 1953 | This model did not have serial numbers. |
| | Model 2A |
N-nnnn | 1955 to 1964 | The "N" is the units digit of the year, beginning in 1955. The "nnnn" is the number of the machine for that year. |
6N-nnnn | 1965 to 1968 | The "N" is the units digit of the year, beginning in 1965. The "nnnn" is the number of the machine for that year. |
N28-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN32-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Mortisers
| | Model 2A Chain |
| | Model 15 Chain |
2nnn | 1953 to 1955 | The "nnn" is the number of the machine within this version. |
| 1956 to 1960 | This model did not have serial numbers. |
| 1960 to ???? | This model did not have serial numbers. |
| | Model 10 Hollow Chisel |
2nnn | 1948 to 1955 | The "nnn" is the number of the machine within this version. Beginning year (1948) is estimated. |
N40-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN40-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Wood Lathes
| | Model 45 |
N-1nnn | 1960 to 1968 | The "N" is the units digit of the year, beginning in 1960. The "nnn" is the number of the machine for that year. |
N45-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN45-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
| | Model 90 |
0-nnnn | 1955 to 1968 | The "nnnn" is the number of the machine within this version. |
N90-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN90-nnnn | 1978 to ???? | The "NN" is the first two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Jointers
===Scroll Saws===
Spindle Shaper
===Sanders===
Drill Presses
===Tilting Arbor Saw===
Wood-cutting Band Saws¶
===Metal-cutting Band Saws===
Planers
