Page History: Patching sheet metal holes using low temp solder.
Page Revision: 2010/02/15 04:53
 before and after |
Getting Started
Prep
A filler for the holes is needed, I used some soft copper from a pipe hanging fixture, hammered flat it was a perfect thickness for this application. For thicker sheet metal,
silver coins or an old copper penny might be a quick source of material. Using lineman's pliers, the plug is cut to shape, slowly snipping into a circle. When I got to where it fit, I pressed it into the hole using the same pliers.
Soldering
Filing and Sanding¶
The finished product
Remember:Do all metal hammering and straightening first.
Clean area well.
Addendum:Just a couple quick notes on soldering. Heating time will vary quite a bit depending on material thickness. I was soldering some 11 gauge sheet steel (0.1250"), and it took about 2 minutes of heat before the solder would flow. That's about as thick as you'll probably find (1/8" thick !), by comparison a Unisaw cabinet is 14 gauge, about 0.08 inches thickness.
When filling thick sheet metal like that I let the copper plug stay a little proud on the show side and dressed it down, the back side I filled with polyester filler (Bondo.)
And, as it deserves repeating, I can not over-emphasize the importance of cleaning the sheet metal thoroughly before soldering. Every time I've found myself hurrying and doing a cursory job I end up with solder not sticking and rolling off, wasting both time and material and making myself feel foolish. Bring the area to a bright shine with sandpaper, wire brush, emory cloth, whatever floats your boat.
