Page Revision: 2010/10/06 02:04
- Quill:
- Upper: 88505 ND > 88505 KS
- Pulley:
- Upper: 88508 ND > 88508 IF
- Lower: 88508 ND > 88508 IF
- Lift table:
- Spindle:
====17" Drill Press==== - 87503 (x2)
- 88503
- Upper wheel: 6202LL Nachi
- Lower wheel: 6204LL Nachi
- Older Style:
- Upper wheel: 87502
- Lower wheel: 87504
- Guides: 6200LL Nachi
- Upper wheel:
- Lower wheel:
- Thrust bearings: 6203
- New Departure 87502
- New Departure 87503
- 87-010 Motor (x2):
- Original: Norma S 3505
- Replacement: KYK 63205
- Arbor (x2):
- Motor:
- Arbor side: 88504
- Rollerhead (x4):
- Original: Fafnir 200KDD15
- Replacement: Nachi 81004
M2 Bandsaw Wheels¶
==Porter Cable==
14" Wood Bandsaw¶
- Pulley: 2x 6205
- Upper Spindle: 6204-3/4
- Shaper spindle: 6203 (x2)
