Page Revision: 2011/09/05 13:18
  • Quill:
    • Upper: 88505 ND > 88505 KS
  • Pulley:
    • Upper: 88508 ND > 88508 IF
    • Lower: 88508 ND > 88508 IF
  • Lift table:
  • Spindle:
  • Cutterhead: R8ZZ both sides
17" Drill Press
    ====Model 6400 - 1/3 hp 1725 rpm Repulsion Induction motor====
  • 2x 88503
    ====10" Grinder====
  • 2x 6206
  • Newer Style:
    • Upper wheel: 6202LL Nachi
    • Lower wheel: 6204LL Nachi
  • Older Style:
    • Upper wheel: 87502
    • Lower wheel: 87504
  • Guides: 6200LL Nachi
  • Upper wheel:
    • one 87504, one 87502
  • Lower wheel:
    • one 87506, one 87505
  • Thrust bearings: 6203
  • New Departure 87502
  • New Departure 87503
  • New Departure 87502 (x2)
Super 900 - Radial Arm Saw
  • Rollerhead (x4):Nachi 81004
  • Bullet Motor: 87504 (x2)
  • 87-010 Motor (x2):
    • Original: Norma S 3505
    • Replacement: KYK 63205
  • Arbor (x2):
Delta/Rockwell 22-101 Planer
  • 6203 (ODE)
  • 6204 (DE)
46-111 14/11 Inch Lathe
  • Motor (1ph and 3ph):
    • Arbor side: 88504
  • Rollerhead (x4):
    • Original: Fafnir 200KDD15
    • Replacement: Nachi 81004
192 18" Band Saw
    • 2x 6306
  • 2x 6204
M2 Bandsaw Wheels
    ==Porter Cable==
    ====G4 Belt Sander====
  • Motor: 2x 6205
14" Wood Bandsaw
  • Pulley: 2x 6205
  • Upper Spindle: 6204-3/4
  • Shaper spindle: 6203 (x2)
