Page Revision: 2009/01/06 22:28
Boice-Crane 1400 6" Jointer
* 6203-LL (17mm B, 40mm OD, 12mm W)
Buffalo Forge No. 18 Drill Press (w/ external screw table lift)
- Quill:
- Upper: 88505 ND > 88505 KS
- Pulley:
- Upper: 88508 ND > 88508 IF
- Lower: 88508 ND > 88508 IF
- Lift table:
Delta Bullet Motor
Delta 14" Bandsaw, Wood Cutting¶
- Newer Style:
- Upper wheel: 6202LL Nachi
- Lower wheel: 6204LL Nachi
- Older Style:
- Upper wheel: 87502
- Lower wheel: 87504
- Guides: 6200LL Nachi
Delta/Crescent 20" Bandsaw¶
- (model 28-350 and 28-365 with rounded corner cabinet)
- Upper wheel: one 87504, one 87502
- Lower wheel: one 87506, one 87505
- Thrust bearings: 6203
Delta Unisaw
- Arbor:
- Thinner/Older spacers: 88503
- Thicker/Newer spacers: 6203
Parks 12" Planer
Walker-Turner 14" Wood Bandsaw¶
